Originally Posted by oledoc2u
Shelton, I am separating my system....how would this fit into the picture? The tank I was going to build, just had a coil running thru it...not under pressure, and would just hold ice. This looks to be pressurized. Doc
Doc, im not sure this is as fancy as what your building. This allows you to separate the circuits to where the s/c coolant goes through the factory tank. The engine coolant goes into this reservoir. So yes this will be under pressure.
