Old Apr 24, 2010 | 05:01 PM
Erzer's Avatar
Erzer
Default Re: @$%^&$# headlight!!!
Originally Posted by waldig
Try a magnet on a flexible rod to get it unless you drove around and shook the headlight. I dropped a valve ( changing springs ) in a 4 cyclinder and got it and reinstalled it by going thru the spark plug hole, you can do things if you wish. Woody
That is the right idea.
I used a telescoping magnet and went in from the high beam side. It may take a couple of days of driving to have it shift around, but you can always use the clip from the high beam until you get it. Good luck Musclefan21.
