Re: any opinions/info on the Dodge Magnums?
I have a 300C with the 5.7 and I like it. But if you do most of your driving in town the gas milage will hurt. It gets low 20's on the highway but around 11 in town. Mine has been a good car. I had the transmission O ring leak fixed under warranty. A shaking while backing up fixed with a software upgrade at the dealer under warranty. My only real complaint is the sunroof that rattles. They fixed it too, for a few weeks, then it started up again worse than before. The interior in the magnum is not as nice as the 300, and the 300 interior is not great, just nice. With a cam and predator you can run low 13's with the 5.7. The stock pistons are weak and those that take the stock block into the high 12's end up eventually with piston ring land failures. Stroker time! I love the look of the Magnum. Good luck on your search.
Les
