Old Apr 25, 2010 | 10:02 AM
Toolman's Avatar
Toolman
Default Re: Tools for Crossfire
Infinite – Thanks for the explaination, I know what you mean. I had to install the special camber bolts on the front end. They only go in with the flat side facing one side or another depending on what camber angle correction you need. The rear lower control arms had standard shaft bolts with T55 heads. To get the camber in on the rear I had to install Kmac adjustable bushings.
