Originally Posted by 32krazy!
howard how about some cold rolled steel and bend to the shape you want? then its one piece with just a couple welds for the feet and tabs
That would work too , i was thinking about alum, oval not flat with a flat piece (plate) that bolts to S/C , Maybe a different mounting location instead of the shockbolt ,the raised part of the innerfender just to the outside of the strut , if you can visualize what i'm talking about ,they are matching raised areas on either side that have small plugs in then,,,
if this makes since
good mounting area for the outside mounting plates
