Originally Posted by nox1s
Do you know if once a keys been programmed to open/lock doors, it can be reprogrammed for another car?
I bought eBay keys for the casing, switched out the transponder/key, but not the motherboard. It starts the car fine, and unlocks it with the door handle, but I cannot for the life of me seem to program it for the buttons to work.
Yes it should, do you have the instructions for programming it? I'll see if I can find them real quick.
Edit: Found it
Originally Posted by Shawnkey
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
- Insert the key into the ignition switch.
- Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
