Old Apr 27, 2010 | 11:08 AM
MikeR's Avatar
MikeR
Default Re: Spark Plugs After Modifications
You should be able to go to the auto parts store and buy the tool... it is very simple and has different wire gauges that fit between the contacts and the adjust the contact so the sire just touches both points. The tool had an arm with notches to use for the tweeking... Once you see it you will understand.....
You could use feeler gauges too.....
