Thread: NO lean Issues
Old Apr 27, 2010 | 01:36 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: NO lean Issues
Originally Posted by SRT6 Gang Member
You, MikeR and Bulldogger are the three X factors I think of when trying to figure out this 20+ lean issue. I'm able to watch boost, RPM and A/F all at once under WOT on street or Track. At this point you three can not, please correct me if I'm wrong BB, MikeR or Bulldogger. If you can't monitor those items or a/f at the least, how can you be sure leaning is not occuring?
Please don't take my post the wrong way, I'm simply trying to find the answer to a problem. Eventually, we will figure this out!
No worries - like the OP said, every modification setup is different.
I only monitor Boost and IAT when on the street. (and I'm soon going to remove those gauges) I monitor AFR when at the Dyno and everything else if the dyno shop is equipped with the STAR system. I know for you drag racers trying to improve between runs it's different.
I can't tell you 100% for sure that I am or am not leaning out a just a TAD momentarily at 20PSI.
In fact the actual time spent at 20PSI is brief. It's not like I hit 6,150 RPM in 4th and hold it there for any length of time before shifting into fifth.
I would love to run my SRT6 at 6,150 RPM in 5th gear for a very long-long stretch of road - but that hasn't happened. Yet. This is why I'm impressed with SLK32Germany's autobahn test results.
I can say; I've never had a CEL since modding my SRT6; Ever. (no - I did not remove the lamp) I've not experienced any type of fuel rail pressure issues. But I believe I will someday with the way I drive - as the OEM pump ages and begins to lose it's UMPH. Then I'll upgrade to the SL55 Fuel Pump.
Even if I was leaning just a tad momentarily at redline - my spark plugs, engine, CEL etc.. show no signs of any damage or impending issues. No performance or driving issues...So why would I spend hundreds of $$ on some complicated fuel delivery modification for an issue that does not exist, or at most, is really a non-issue?
If your SRT6 is cutting out or losing power or burning up spark plugs - that's another issue.
I'm not saying that spending big $$ is a waste if there are huge gains (or decent gains) to had. I just haven't seen them yet. So I have a "wait and see" adittude before I bolt on anymore mods...(except the upcomming mods on my list)... but I'm fabbing them up myself...that's half the fun...
