Thread: NO lean Issues
Old Apr 27, 2010 | 03:48 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: NO lean Issues
Originally Posted by Xray
In 3rd gear at 5200 rpm's I start to lean out climbing very rapidly to the 15's and higher without the fuel mods. In 2nd gear it starts to lean about 5700 rpm's. These lean conditions coincide with WOT and boost hitting 19+ psi. I have over a hundred logs and this happens every time the only variable is that at what rpm it starts to lean and this is consistent with DA and how quick I am building boost. Go Woody I know you can find a straight forward fix for this.
Have you pulled and inspected your spark plugs?
If they look bad - you could possibly be melting your pistons or valves. That can't be good for drag racing...
