Old Apr 27, 2010 | 06:49 PM
onehundred80
Default Re: Dremel Suggestions?
Originally Posted by xodus52
Thanks for the suggestions. Unfortunately I live in a metro area and have to work on my baby outside away from an outlet, so i'll have to get a battery powered dremel. I've linked two options below; would either of these have the speed/torque to shave rust/caked on carbon off the exhaust tips/muffler? Or conversely, is there any easier way i can take this gunk off without a dremel, that i'm overlooking?
Amazon.com: Dremel 8000-03 10.8-Volt Lithium Ion Cordless Rotary Tool: Home Improvement
Amazon.com: Dremel 750-02 Minimite 4.8-Volt Two-Speed Cordless Rotary Tool: Home Improvement
Much thanks.
PS. I've tried carb and choke cleaner.
Go with the higher voltage, batteries suck so get the most powerful you can, 4.8 volts is barely enough for an electric toothbrush.
These things may rev a lot but put a load on them and they stall really easy.
