Originally Posted by Violenteer
gurus:
will this work:
19 x 8.5 - 43mm offset
20 x 10 - 42mm offset
will i need spacers?
let me know what you guys think...
Well, These are the sizes I'm using but I don't know if the ofsets are the same. I can tell you, there WILL be rubbing. I'm going through hell now trying to reduce mine. If the car is not lowered, you may be OK, but I'm using the Eibach pro kit, and I cut the bump stops in half over the weekend, and the rubbing was so bad I couldnt drive the car. I ordered the 19mm spring pads and I'll be ordering wheel spacers as well to try to get rid of the rubbing. The ride is MUCH better with the bump stops cut by the way.
