Old Apr 27, 2010 | 10:59 PM
Valk
Default Re: Tire Noise / Cheap Tires ($66) / Laugh if you must
Originally Posted by xodus52
Interesting, I just ordered a set of Hankook Ventus Evo's from tirerack and am getting them put on saturday. Should i get an alignment at the same time? I'd assume they would be balancing the tires correctly when putting them on initially, right? (BTW I'm around 50k miles.)
If your tire wear looks even across the tread leave it alone.
Mine has 56000 miles and wear is perfectly even across all 4 tires
30,000 on the fronts and 18000 on the rears when I replaced them with the Hankooks.
Steering straight and no pulling either way on the road.
If it aint broke don't fix it
