Originally Posted by SRT6 Gang Member
You, MikeR and Bulldogger are the three X factors I think of when trying to figure out this 20+ lean issue. I'm able to watch boost, RPM and A/F all at once under WOT on street or Track. At this point you three can not, please correct me if I'm wrong BB, MikeR or Bulldogger. If you can't monitor those items or a/f at the least, how can you be sure leaning is not occuring?
Please don't take my post the wrong way, I'm simply trying to find the answer to a problem. Eventually, we will figure this out!
I told you I can with the Auterra the only problem I had was recording the data, which should be resolved since I downloaded their patch. When I ran the car full out in 4th I had no lean conditions my readings were off the factory o2 sensors and not using a wide band. Right now I am in the process of supercharging my vet so playing with the crossfire is on the back burner
