Thread: NO lean Issues
Old Apr 28, 2010 | 08:53 AM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: NO lean Issues
Originally Posted by Bulldogger
I told you I can with the Auterra the only problem I had was recording the data, which should be resolved since I downloaded their patch. When I ran the car full out in 4th I had no lean conditions my readings were off the factory o2 sensors and not using a wide band. Right now I am in the process of supercharging my vet so playing with the crossfire is on the back burner
You did, thanks for reminding me, I went back and reviewed our chats. You hadn’t reached 20+ psi which IMO is why you haven’t gone excessively lean like I had. I have the same data logger as you, plus a wideband a/f gauge because our logger can’t perform wideband a/f analysis asis.
The O2 sensor will only show you the excessive lean (17.00) condition, indicated by a drop in voltage from .800ish to .200ish, which is triggered by 20+ psi. It will not show you the acceptable lean (11.8 to 12.8) condition that all of us ::have with boosted pulleys::, that’s why I said to notice these things one NEEDS wideband capable equipment.
Enjoy the vet bro, it’s a beauty!
::edit::
