Thread: NO lean Issues
Old Apr 28, 2010 | 08:56 AM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: NO lean Issues
Originally Posted by MikeR
My first thought was.... we all have Aero Blue cars... nuff said.....
I have a Zeitronix and Dashdaq II..... the Zeitronix had to go back to check out and I should have it back tomorrow.. then have to find out why it stopped giving me output to the laptop/Dashdaq..... I should be able to get some AFR/Boost readings soon... previouse laptop readings did not show an issue, but I wasnt running WOT at the track....
Hey, I have an Aero Blue also; I must have one that was manufactured on a Monday or Friday !
Let us know what you’re a/f findings are once its back up and running, if you don’t mind. I believe you will notice the acceptable lean condition, where you’re a/f leans out around 5400 rpm in 3rd (max boost). Example: At WOT a/f will be 11.8, by the end of 3rd a/f will be leaner around 12.8. Those are my numbers but you should see a similar curve.
