Old Apr 30, 2010 | 05:43 PM
  #61 (permalink)
ChuckNorris's Avatar
ChuckNorris
Default Re: Engine and Transmission from '04 Limited
Parts still available
Gauge Cluster
Temp sensor
thermostat housing with thermostat
block
crankshaft
rods w/pistons
upper and lower oil pan
torque converter
coil packs w plug wires
serpentine belt
yaw sensor
camshaft position sensor
skreem module
idler pulley
camshafts
heads
rocker assmeblies
OEM spark plugs (32kmiles)
water pump (6kmiles)
AC Compressor
transmission
starter
I'm sure there is other stuff I am forgetting to list.
