Re: Please respond- Intercooler Pump!!
First, I would like to say "sorry" for the down time. Now to answer your question about "being too far off"---the answer is yes you are. I know that you are upset, but here's why you are "off." I had a three tire stores for 10 years and saw this all the time. People thought a powertrain warranty covered more than it did---you may have even been told it did cover more. 70GT6 is right about reading the policy. A car will not go far without a water pump either, but it is not covered under a "powertrain" only warranty---neither is a radiator, and a whole list of other parts. We all must have both of the above, but they will not be covered. You will be happy that you have it should you loose the transmission or engine, but a word of advice. MAKE SURE you have ALL paperwork on maintenance for TIME and/or MILEAGE because like 70GT6 said if you read the policy, the warranty will be VOID if the services are not done---I have seen it, so be careful and prepared. With low miles, you need to watch the TIME, or the warranty that you do have will be no good!!!!!
Now, you are right about the recall. I see way too many bad pumps on here, but with the failure not being a safety issue and the fact that it is a low cost part, we will never see a recall. Good luck---Buy the pump and love the car!!!!!
