Old May 1, 2010 | 04:14 PM
Franc Rauscher
Default Re: Can a Johnson ever be too big?
Originally Posted by FireAnt
Are "wares' the same thing as ******?...If so, I guess if your Johnson is responsible for a bunch of "wares"....He mus' be a pimping mack daddy...
But seriously folks...I've done a little research and the CM30p7-1 comes in both 5/8" and 3/4" sizes.
Which be da right one fo our application?
Oh BTW, thanks Montana Crossfire for the words of caution...I plan to isolate the intercooler system from the engine setup which should give me a net reduction in pressure on the intercooler core...I think...
Internal pressure is minimal when you are sumping what you are pumping so a higher capacity pump isn't likely to be an issue. Pressure is the result of resistance against the pump or a volume increase the result of temperature expansion in a closed captive system. By separating from your engine system, this is to be an open (ambient) system so, I don't think that is an issue here either.
My two rubles worth.
roadisaster with a steek
