Old May 3, 2010 | 05:33 PM
Darticus's Avatar
Darticus
Default Re: Anyone have this happen to them: oil leak
Originally Posted by AllEuro
I have heard quite a bit about owners talking about needing to replace their valve cover gaskets because of oil leaks, but I have an oil leak that I don't recall reading about. A leak at the gasket where the oil filler neck is attached to the valve cover. I suspect this may have something to due with the fact that the delaer ALWAYS overfills the oil in the car when they change it. After one oil change, the oil light indicating too much oil went off a few times until I had them drain the excess.
According to the crossfire tech at my dealer, a leak here necessitates replacing the entire valve cover as the gasket at that location is not serviceable. Just a public serivce message for those who care!
They did replace both valve covers and gaskets and an upper round gaskets were also ordered by the dealer for replacement. Are these the two you say can't be replaces? Ron
1-5097104-aa gasket cy 9001004
1-5097105-aa gasket cy 9001004
1-5080088-aa gasket OI 9001004
1-5096479-aa cover cyl 9003027
1-5096480-aa cover cyl 9003027
