Old May 5, 2010 | 01:02 AM
onehundred80
Default Re: Oil Level Sensor Location and Testing
Originally Posted by waldig
Drain your oil, then add 1 qt at a time till the reading comes back "up" . You could use the same oil if its new, just keep track of the volume added so that you know what you have. Woody
He says the sensor is not working, the dip stick would tell you how much oil you have.
Look in the shop manual and see how it's fixed.
See section 9-672
OIL LEVEL/TEMPERATURE SENSOR
REMOVAL
1. Remove the lower oil pan.
Refer to Page 9-663.
2. Disconnect the oil level/temperature sensor harness connector
(1).
3. Remove the two oil level/temperature sensor screws (1).
4. Remove the two harness retainer screws (2) and the oil
level/temperature sensor.
