Re: Stacked Fuel Pumps
Exactly if you are at -10 in vacumn and go to plus 20 under boost you will raise pressure 30lb's. When you go from -10 to -9 you have added 1 pound of pressure even though it is still negative it is a raise in pressure. If you set your pressure under vac and then disconect the vacumn so it is at atmospheric pressure the fp increases.
