Re: I found the problem! Pics inside
Musclefan21, you need to take a drill and some bits, a strong punch and heavy hammer, a propane torch, grade 8 bolt and nut and figure it out. It can't be worse than a ball joint that's riveted in that has to be replaced. I've had the bracket apart several times but can't say how the stud is inserted. From the lightweight stamped metal that surrounds the rubber on the sway bar I doubt it will cause you too much trouble. I'll most likely have the front of my car apart AGAIN this weekend and if you haven't solved your problem by then I'll take a real good look at it.
Les
