Old May 6, 2010 | 09:29 AM
donschorr's Avatar
donschorr
Default Re: Car almosts stalls coming to a stop sign/redlight
Originally Posted by apkano
Pull the negative battery cable for 1/2 hour and then reattach. You're basically resetting the learned history in the PCM.
I had the same problem once at about 50xxx miles only when I exited the expressway......it hasn't come back.
I recently reset it inside the car.............
but
I just pulled the neg cable and cleaned the positive cable/post- had a little build up not much IMHO.
I will try to see if doing the negative cable helps.
Thanks for your suggestion.
Don
