Old May 6, 2010 | 11:16 AM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: Car almosts stalls coming to a stop sign/redlight
Originally Posted by donschorr
I recently reset it inside the car.............
but
I just pulled the neg cable and cleaned the positive cable/post- had a little build up not much IMHO.
I will try to see if doing the negative cable helps.
Thanks for your suggestion.
Don
Pulling the battery cable for 1/2 hour will reset the PCM (powertrain control module)....... you usually reset the FSS (flexible service schedule) from inside the car.
