Old May 6, 2010 | 08:52 PM
donschorr's Avatar
donschorr
Default Re: Car almosts stalls coming to a stop sign/redlight
Originally Posted by Blast Chamber
Does the car still have the original OEM battery? If so, it is 6 years old, and there have been cases of older batteries with lower voltage causing weird symptoms in the Mercedes electronic systems.
I realize this is thin and is just a WAG on my part, but if you are soon due for a new battery anyway it may be worth a try. I'll be replacing my OEM battery next week even though I'm currently having no problems.
Battery has not been replaced but had my mech check it out- tested fine- do you think it could cause a problem when it tests OK?
Thanks
Don
