Thread: Issue
Old May 6, 2010 | 11:48 PM
oledoc2u
Default Re: Issue
Originally Posted by xX MIKE Xx
I was idling for about 25 minutes I hear a little pop followed by a constant low pitch noise. I then immediately shut the car off. I turned it back on and there is still the low pitch noise. I went to go drive it the supercharger is not kicking in and there is a real loss in power. I don't know what happen. I was reading the forum and im seeing it could be a possible IC Pump failure or air intake sensor. Can someone please let me know what I should do thanks
you already said it....it's either sensor, telling the puter the SC is hot, and is shutting it down, or the IC pump has failed...my money is on the pump since there is noise associated with it....if no warranty, there's a johnson pump, ford lightening pump, and the bosch oringinal equipment.....the first 2 require a little wiring and plumbing...there's a "how to" on here somewhere for that...
