Thread: Issue
Old May 7, 2010 | 08:58 AM
Bladecutter's Avatar
Bladecutter
Default Re: Issue
Originally Posted by xX MIKE Xx
The intake sensor.?..?. How would I know if it is not the pump?
The answer to that is quite simple.
You look at the IAT Sensor, and see if it is not tightly inserted in the hole for it.
If its loose, then it NOT the pump.
If it's tight, and inserted correctly, then it's something else.
Simple.
I still have warranty on the car should i bring it in? Is it possible to put the intake sensor back in the hole? Does this happen to all car with superchargers if idled to long ?
You can do whatever you want, its your car.
If you find the sensor loose, try it, and see what happens.
I doubt very many people leave their SRT's idling for 25 minutes, but no, I don't think that's a normal occurrence.
Normally I would ask why you had your car idling that long, but I don't think I truly want to know the answer to that.
The time for action is NOW!
BC.
