If you look at the picture that BrianBrave posted you can see the sensor has two clips that just pop over the edge of the flange that the sensor goes through on the Y pipe. This is mounted right below the throttle body. You will need to take the air intake off the TB, and likely the TB too, to get at the sensor easily. It shouldn't take more that about 15 minutes to check/fix if that is it......
