Re: New member & trouble with TPS and BAS/ESP
If I am correct you will have to have the sensors re=calibrated to the car, I had a simular problem when I installed a new wheel it came off another car and after a couple of days the TPS light came on, I took into the dealer and they matched it to the system or re-calibrated it, and everything was fine there after. Do a search for the BAS light I think you have to re-calibrate the system by turning your steering wheel all the right and all the way left to calibrate the steering angle sensor?
