Old May 10, 2010 | 11:13 AM
onehundred80
Default Re: How do I Jack up my XFire with a FLOOR JACK???
Thanks for asking that Rad as I was thinking the same thing. if it's on the pad, then the only way I could think is that if the entire side of the car is going up, then you jack the front, slide a stand under the rear, lower the jack and the car is still up, so then slide another stand under the front.
That would work using adjustable stands, but stands that have fixed increments would not be touching.
These cars are tough to put on stands using the points indicated in the repair manual.
But there again I don't know jack.
radmanly asked, If you use the pads to jack up the car, how do you swap out the jack for a jack stand?
Answer, very quickly
