Originally Posted by AllEuro
If you guys really want to see how long you should be changing your oil or if the FSS is accurate, you should spend the money to have a sample of your oil analyzed at your next oil change. These guys,
Blackstone Labs seem to be pretty well known for their oil analyses. This is really the only way to see if the generalities mentioned in the original article hold true for your car and how you drive it.
Thanks for the tip, AllEuro. I had NO idea it was this reasonable to have it tested, this is must for everyone trying to wring out as much power as you can from this 3.2
