Old May 11, 2010 | 04:29 PM
BoilerUpXFire
Default Re: CPS Issue & More
+1, I just had to replace my crankshaft sensor and now everything is running tip top
If you need to do the cam sensor later, you can, but at the stealership, their approach is usually - replace everything that could be the problem.
Also, do it yourself, you will need a serious extension for your wrench and the angle is a little strange, but overall, I consider it a pretty simple fix for the do it yourselfer....
