Re: coolant recovery/overflow/expansion tank
I am on my fourth epoxy, but this one seems promising. I had tried the high temp or JB weld compounds and the JB epoxy worked the best, it still didn't hold fast to the surface. The fluid was able to get under the hardened material and find a escape route. I am hoping this Plastic Weld Epoxy will bind better to the tank and keep the pressure and fluids where they belong.
If I were to spend 100 dollars on a replacement, it would be a nicer aftermarket addition. There are alot on ebay but didn't know what models carry the same tank as ours. I was hoping someone that had the information from past replacement would chime in, so I could get it on order immediately. Thanks for everyones help, and I should be better prepared if and when this bandaid comes off.
