Old May 12, 2010 | 11:34 AM
onehundred80
Default Re: coolant recovery/overflow/expansion tank
Originally Posted by goodgenes79
I am on my fourth epoxy, but this one seems promising. I had tried the high temp or JB weld compounds and the JB epoxy worked the best, it still didn't hold fast to the surface. The fluid was able to get under the hardened material and find a escape route. I am hoping this Plastic Weld Epoxy will bind better to the tank and keep the pressure and fluids where they belong.
If I were to spend 100 dollars on a replacement, it would be a nicer aftermarket addition. There are alot on ebay but didn't know what models carry the same tank as ours. I was hoping someone that had the information from past replacement would chime in, so I could get it on order immediately. Thanks for everyones help, and I should be better prepared if and when this bandaid comes off.
Lots of compounds do not stick to plastic. One way that might work is a small wood screw screwed into the hole. This relies on the taper to jam into the hole.
