Old May 12, 2010 | 08:04 PM
bmorgan's Avatar
bmorgan
Default Re: Might buy a roadster?? need advice
There are problems and issues with the roadster,
More Chicks wanting to ride in your vert.
You can't get a pony (beer pony) in the trunk.
There is that annoying exhaust sound
You can hear nature when you drive.
More head room, even when the top is up.
It is possible to have sex in the roadster. Not easy but posssible.
When the temperature is over 53 degrees F you are required to put the top down.
You can't drag race at the track if you mod it to do the quater mile below 14 seconds.
Your wife won't let you put the top down if it's only 53 degrees.
She probably won't let you have sex in it, even if it is possible, and even if it is with her.
The Crossfire was made to be a roadster. The coupes are OK but the roadster is perfect. Especialy if it is a stick shift.
If you can get past these problems, I'm sure you will like the roadster.
roadster with a stick
"the way is should be"
Unless you have a home track like mine that does not enforce it.
