Old May 13, 2010 | 07:15 PM
ImportLabSRT's Avatar
ImportLabSRT
Default Re: Broke a part need help
Go down to the hardware store and by a 1/4" brass 90* fitting - cut the barb from the brass end of the 90* - drill out the broken stem at the filler neck so brass fitting will fit in tightly - remove and scuff both pieces - use some two part epoxy and re-attach - might work...
Is the tank thick enough to be tapped??
