Old May 13, 2010 | 07:41 PM
onehundred80
Default Re: Transponder ring wiring
Originally Posted by alcast082
Where does the transponder ring wire connect, I've been looking but can't find anything
SENTRY KEY REMOTE ENTRY MODULE
DESCRIPTION
The Sentry Key Remote Entry Module (SKREEM) (1) is
located underneath the top pad of the instrument panel (2)
behind the Instrument Cluster. The SKREEM works in conjunction
with the vehicle locking/unlocking remote control and the
Central Locking Pump/Security System Module to lock and
unlock the vehicle.
The SKREEM is also the primary component of the sentry key
system. The SKREEM has a halo-like Antenna Ring that connects
by wires to the SKREEM and is mounted around the
Ignition Lock Cylinder. The SKREEM cannot be adjusted or
repaired. If faulty or damaged, the unit must be replaced
