Re: Broke a part need help
Originally Posted by RIOT
so how about an answer to 1 and 3?
By the way is there copper up inside that tube on the tank in the photo?
Cause there is copper inside the hose end...and no 90 of plastic left at all....to me it looks like it should be a straight shot into the tank not a 90.
Is there that much pressure on this to pop it?
Somehow there is a vacuum held in the reservoir, so there must be some pressure.
I have found that using epoxies to mend plastic does not work too well. There needs to be a bond and PE does not bond well, glues and epoxies come in plastic tubes for a good reason. It sometimes looks good but any force and it separates cleanly. PE can be welded with the proper filler and the right equipment.
Finding a replacement is my best idea.
