Originally Posted by andyd
CHRYSLER CROSSFIRE 2002+ Retrofit Flat Wiper Blades on eBay (end time 25-May-10 12:46:37 BST)
I put a set of these on about 6 weeks ago.
They look pretty sleek and clear the windscreen perfectly. No noise, even when dry!
Only slight niggle is that the passenger blade is slightly longer the=an the standard blades and just touches the rubber trim on the windscreen surround. Not a problem so far. I'm monitoring it and if it seems like it's causing any damage to either the surround or the blade I'll just cut a few MM of the end of the blade. I'll try and post a picture later.
Regards, Andy.
Cheers Andy - I've ordered a set of these today so they should be with us by the begining of next week. Thanks to all the folks that responded.
