Re: Anyone have problem with Costco gas?
Do you have ethanol added to your gas in Toledo? Because the water-ethanol mix is at the bottom of the tank, the fuel pump may pick up a slug of this mixture, and the engine will run very poorly or perhaps die. Or, they could have exceeded the ethanol content posted on the pump. That is becoming a more common problem these days as it's used as an additive to reduce the price of the gas.
