Old May 16, 2010 | 05:37 AM
crossfirefun's Avatar
crossfirefun
Default Re: drive cycle blues
Make sure the wire for the computer memory is constant on. Fuse could be burnt.It could be resetting every time you turn off the key. Happens on a lot of cars.
When you work on the car you should use one of those 9 volt battery adapters plugged into the cig. lighter, just dont open the doors as that will kill it quick.
