Originally Posted by crossfirefun
Make sure the wire for the computer memory is constant on. Fuse could be burnt.It could be resetting every time you turn off the key. Happens on a lot of cars.
When you work on the car you should use one of those 9 volt battery adapters plugged into the cig. lighter, just dont open the doors as that will kill it quick.
not sure which computer your talking about. if its the dashdaq you mean rcompart helped me set it up and its fine. he does a fantastic job of walking a non electrical guy thru the process and i have zero issues with it. i actually have been battling this issue since feb when i started to get emissions done. before my dashdaq install, had to disconnect the battery to solder all the connections. the main reason is i dont like to put a ton of miles on my car and would have thought my 1000 mile trip would have reset it.
