Old May 16, 2010 | 01:57 PM
onehundred80
Default Re: Motor mount help!
Originally Posted by MikeR
I have never done mine, but I would think if you start lifting the engine with a jack you will be able to tell pretty quickly by looking at them if one is broken.... your description sounds like one is...
I think the transmission it mounted on the back of the engine and will torque/twist with the engine on acceleration.....
You had better be careful where you put the jack when lifting the engine. Do not use the sump pan.
