Re: Power steering
They should be using Pentosin CHF 11S its in a green can and this is the only fluid that should ever be used, other fluid may damage the system, you can check the color in your resevoir to make sure it's green if not, I would be taking it back and have them fix everything, and I yet have not heard any x-fires needing P/S fluid, and mine has stayed the same level since new, and if it did need more fluid then there SHOULD be a LEAK somewhere !
