Old May 18, 2010 | 03:11 PM
  #39 (permalink)
Nexxus's Avatar
Nexxus
Default Re: New interior trim
If you EVER put on vinyl for the interior, make DAM sure the stuff is made with 3M. It looks like whoever put this on used some additional glue. Very bad.
But it looks like you have almost got the most of the damaged repaired. Great work!
And a note: If you ever need to remove vinyl from the interior, use a good steam gun. List a small edge, apply the steam under the vinyl, and SLOWLY peal it away. If done correctly there should be no residue left and the interior will look as if its never been touched.
If you ever put vinyl on, MAKE SURE to read and follow the directions. Failure to do so may cause damage to your interior.
