Installed a Code 3 intake and code 3 Pulley (GAINED NO POWER)
May 18, 2010 | 08:36 PM
41
permalink
waldig
Feb 2008
4,508
34
VA
Re: Installed a Code 3 intake and code 3 Pulley (GAINED NO POWER)
Just me but in a pinch you can measure the circumference of the pullies and get meanigful readings without a indicating caliper. C = Pi x Diameter.
Pull the tape measure out wrap it around and measure from like the 1" mark to the end of the tape where it crosses. Remember that you started at 1" ( to avoid the lump on the end of the tape ) and you have the diameter with a bit of a calculator. Pi is about 3.1416 FYI.
6.28 or 6.25 would be about 2" in diameter. If you have a mm tape life is easier; otherwise to get mm just multiply inches by 25.4, thus 2" would be about 50.8mm
Woody
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
