Originally Posted by Infinite
the way that guy has his done wouldnt pass tech for any sanctioned motorsports body. It has to be in an enclosure mounted to the car.
i already have an optima yellowtop as well as the relocation kit. There is no way to mount it properly to the trunk floor due to the hump in the middle, i'd have to box it in with plate in order to mount it properly and securely.
Im diong this because The battery and ecu enclosure are in the way of my turbo setup Im working on, by relocation the battery to the trunk i can move the ecu enclosure over to have enough room to run a single under the hood
I suppose I didn't know you were trying to pass race spec inspections I just thought you were trying to stealthily relocate to the trunk.
