Re: Fuel pump question
If you see a puff of white smoke when you start, you have a fuel injector that is leaking fuel into your engine when it sits. This is a common problem on older GM cars.
Also, if your fuel pump is going, you will have hard starts for a while then it will cease to run at all; learned that from experience.
