Old May 22, 2010 | 03:42 PM
oledoc2u
Default Re: Master Light Stitch light wont go off on dash!
Originally Posted by DBLO57@rogers.com
Thank you for your response. I don't know what an "hid's" is (similar to an led?). Anyway, I replaced the tailight/brake light bulb (not an led) but I did install an led illuminated wind restrictor last year (but the master light switch indicator did not indicate a problem then - only after the ordinary bulb burned out (which has since been replaced but the master light switch indicator remained illuminated even afterwards).
Any suggestion?
Thanks again.
checked to see if both your license plate bulbs are working?
