Old Apr 7, 2005 | 12:31 PM
babeviper's Avatar
babeviper
Default Re: Wheel Offset Compatibility
Originally Posted by Cyril Baldwin
Thanks for your reply Big Ron.
I was just wondering why some XF members here use wheel spacers 10mm front and 12mm rear in their stock rims. Is that the allowance we have in our wheel well in case be buy aftermarket wheels with >35mm offset?
cyril, if you can find a wheel thats 37mm all around, then you will only need a 12mm-15mm hub-centric spacer for the rear the fronts will fit perfectly without a rubbing problem and you won't need a spacer for the fronts.
